Hi All;
I have a problem with my salamander shower pump. The installation pipework was done before we bought the house and meets the full manufacturers guidance in the installation guide. A salamander pump was fitted and ran fine for the first year we were in before it expired from old age. I replaced the pump with a direct replacement to the same spec - a CT50. This ran fine for a few months then started playing up. It turned itself on without the shower being on at all. Since then it refused to be controlled by the water flow and remained constantly on. I removed it from the system, checked the flow switches weren't stuck and flushed it through (this was the advice from Salamander) but it still wouldn't work. Took the pump back to the stockist and had a new one - exactly the same fault developed. Now have to turn on the shower before manually turning on the pump and then leaping out of the shower at the end to turn of the pump before switching the shower off. Its driving my wife insane! Any ideas or diagnostic checks I could run?
