Hi All,
My Samsung WD8704RJA washer dryer has stopped draining with a 5e error code. I have checked all hoses and the pump filter for blockages and have then tried swapping the pump.
I still have the fault and the pump does not run at all and makes no no noise. Both the old and new pumps give about 200-300 Ohm with a multimeter so the old pump seems to be ok. I think it is not receiving power from the controls but don't know where to test.
I have tried testing for voltage at the spade connectors on the pump and there was no voltage at all during a spin cycle. I measured AC volts as the pump is 220-240V AC 50-60Hz and set the meter to log the peak voltage during the cycle but there was nothing at all.
Where should I look next? Will it be the main PCB or are there usually some in-line components to test between the pump and main board first?
Any help or a service manual would be greatly appeciated as the washing is piling up with a 6 week old baby in the house!
Thanks,
Mike
Thanks,
Mike
