Sandstone as backfill and concrete mix.
18 Mar 2026
Hi All.
Please be kind. I'm in the early stages of an extension and our first few courses of block work have gone in.
We've got alot of space either side of the block work that needs backfilling.
We have an awful lot (about 32t) of sandstone Gabion rock. not limestone gabion. its a yorkshire sandstone
My question is, can I crush the the gabion stone and use it for back fill on both the outside and inside of the block work/or just one side? or does it have to be any particular material? or indeed 'not' any particular material. I ask because of the water retention properties of sandstone and curious if this will this cause any issues later on.
Does anyone have any thoughts on this?
My thoughts would be that it would be an awful lot of work to crush it. Could you not just put it in as loose fill then pour quarry waste or similar in to fill up the air gaps. I don't think Yorkstone would be as absorbent as red sandstone.
jj4091, I was thinking i could maybe use it to make up the concrete for the over-site, and maybe to fill my hollow blocks. im thinking of hiring a crusher for a day.​
Do mean a base for the over site. It's still going to be a hell of a job with a crusher, but I've never seen one that you can hire so don't know what sort of capacity they have.
I think you will need to fill hollow blocks with concrete rather than loosefill and I think you would need to do that first to prevent them getting broken. Never used hollow blocks in footings so can't really advise anymore than that.
OK yes you can hire small crushers. You're below dpc so water retention not an issue,
What floor is going in: if a ground bearing slab then you need to make sure your fill is compacted and a simple way forward would be to pack the stone in like a dry stone wall so it becomes a rigid lump or you could cheat and slop in a bit of mortar. Outside less critical arguably because you could allow the stuff to settle naturally before you pave.
Concrete for infill blocks.
I was meaning to crush the gabion and use it like MOT to level the ground works, and then use the rest to mi with some sand and cement in a mini mix to make concrete and use that as an oversite layer. Its not structural and wont be walked on. its block and beam above it.
