I've got sandstone steps outside leading down to the basement. They're worn and chipped so I've started removing some of the surface to get them flat again (as they would have been 100+ years ago).
I'm using one of these: http://www.toolstation.com/shop/Abr...g+Disc+100x22mm+Double+Row/d130/sd1450/p62515
What should I use to get the circles and slight irregularities out?
Would course sandpaper on a block be good enough, or is there something else a pro would use?
I've removed all the steps btw, as I'm realigning them.
Any advise gratefully received.
