Hi looking for some advice
What best adhesive I can use to put 6 sandstone tiles which are only 20mm thick on to brezze blocks. Going to used on a water feature
Use a good quality exterior tile cement suitable for natural stone like BAL Supercover rapidflex. You will need to support them with battens or something as it goes off because they will be too heavy to stay in place.
Its porbably worth priming the back of the tiles with an SBR cement slurry as sandstone has very high suction. Ask the BAL technical dept
