    Dismiss Notice
Saniflo trips the house circuit breaker: repair or replace?
Discussion in 'Plumbing and Central Heating' started by pred02, 25 Jan 2021.
  1. pred02
    pred02
    18 Sep 2014
    30
    Thanks Received:
    London
    Country:
    On Saturday my Saniflo unit started tripping the house circuit panel. I tried changing the 13A fuse at the switch but it's still happening. A plumber came and check to see if there was a leak, but he did not open the Saniflo unit to see inside. He did not see any loose wiring either. He said it's a replace unit which is about 450 GBP plus labour. The unit is exactly 5 years old.
    Is it worth getting a Saniflo specialist or just look for the cheapest unit to replace?
  2. Sponsored Links
  3. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,322
    Thanks Received:
    1,893
    Hertfordshire
    Country:
    Move house.
    Andy
    • Like Like x 2
  4. pred02
    pred02
    18 Sep 2014
    30
    Thanks Received:
    London
    Country:
    I get it. I am not pleased to have to spend £££ after replacing it a few years ago. But right now plumbing the whole flat is not an option.
  5. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,322
    Thanks Received:
    1,893
    Hertfordshire
    Country:
    Do you have 2 toilets in the flat?
    Andy
  6. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,322
    Thanks Received:
    1,893
    Hertfordshire
    Country:
  7. just pumps
    just pumps
    24 May 2016
    2,600
    Thanks Received:
    434
    Country:
    Sounds like the windings are failing. Wire it to a plug and try a wall socket for now to buy you time. Nothing a sani specialist can do.
  8. just pumps
    just pumps
    24 May 2016
    2,600
    Thanks Received:
    434
    Country:
    OP said house not flat and law says there must be one on mains drainage.
  9. pred02
    pred02
    18 Sep 2014
    30
    Thanks Received:
    London
    Country:
    Sorry to clarify when I turn on the switch at the unit it buzzes for 2 seconds and then goes out. It trips the house circuit so all appliances on that circuit go down as well.
  10. Sponsored Links
  11. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,322
    Thanks Received:
    1,893
    Hertfordshire
    Country:
    He said flat.
    Andy
  12. just pumps
    just pumps
    24 May 2016
    2,600
    Thanks Received:
    434
    Country:
    Point taken, OP mentiond both.
  13. just pumps
    just pumps
    24 May 2016
    2,600
    Thanks Received:
    434
    Country:
    Sounds like a wet wipe/ something jamming the blades.
  14. pred02
    pred02
    18 Sep 2014
    30
    Thanks Received:
    London
    Country:
    I need to make a call whether to get an Saniflo engineer to try to fix it or go to replace it. If he tries to replace it, it is a potential £200 sunk cost. Replacement is likely £250 for labour and £500 for parts. Not cheap!
    Could it be something simple as a broken switch or a stuck item (we haven't thrown anything in it but could he hair etc from the shower)?
  15. just pumps
    just pumps
    24 May 2016
    2,600
    Thanks Received:
    434
    Country:
    IF you are certain that there is nothing inside jaming the blades (and creating the buzzing) then I advise replacing.
    If it was me and found the unit couldn`t be repaired then the time spent finding out was charged at a hourly rate so there shouldn`t be any £200 +£200 + £500 costs. Talk and get this agreed before starting or pop the lid off and check yourself.
  16. just pumps
    just pumps
    24 May 2016
    2,600
    Thanks Received:
    434
    Country:
    For the OP
    I see that WC1 has said that 5yrs is an acceptable life span, well, he may know gas but he knows sod all about macerators unless he refers to cheap sub £200 units from fleabay.
Loading...
Share This Page
