Santon fixed temperature immersion thermostat
19 May 2015
Hi .
Can you still get the fixed temp stats 140 or 160 f? If so, where please.
Thanks................
You may need to be a little more specific over exactly what you are looking for.
Celsius has been the unit for temperature for the last 40 years so if there were any they be designated in degrees C.
Why not explain what you want to achieve?
Tony
I'm looking for a fixed temperature thermostat for a Santon 11" immersion heater. The fixed temperature stat would have a fixed temperature of either the Celcius equivalent of 140 degrees Fahrenheit or 160 degrees. Roughly 60 C or 70C. Or a modern replacement that will fit this style of heater. I'm trying to achieve not having to replace an immersion heater in a tank that has been damaged
when this heater was fitted in the 1960s.
Thanks....Phredd.
