Posted on here a few days ago about a noisy Saunier Duval 623 boiler. The noise is being caused by the small rubber bushes the fan attaches to the casing being worn out,allowing the fan to vibrate against the mounting posts and casing.
Last night the boiler failed completely! When the thermostat triggers the heating on or the hot water tap is run the boiler fires up but then the gas cuts out approx 10 secs later (can hear a relay click) and leaves just the pilot light. The fan is still running afterwards.
The problem is the plumber who is going to change the boiler is not available for a week and we don't have hot water or heating. It sounds like a cutout switch has failed or possibly the control board? I have tried leaving the boiler off (gas and electric off) overnight and turning it back on
next morning.
Is there anything obvious I can check or do to get it working until I can get the plumber in?
Thanks in advance.
Martin
next morning.
Thanks in advance.
Martin
