Hi All,
Im new here and thought I'd see if I can get an answer to fix my issue.
Ive had the boiler for about 3 yrs and on searching the forum, I get the hint that there NOT very good, but Im stuck with it.
The problem is that recently I had it serviced and the Heat Exchanger was replaced. The hot water works great and the heating is much better. However Ive noticed the pressure goes below 1 bar and then the boiler switches off (red light comes on). I then have to release the pressure by turning the valve back upto 1bar. This gets everything working again until the pressure drops again. Also the overflow pipe outside is letting out very hot water when the boiler is on.
Any ideas ? so Im prepared as not to let the plumber fob me off with more costs.
