Scarification
14 Sep 2010
Hertfordshire
Bits of my lawn are yellowing even though I water it regularly so I raked some up as you can see here. Is this natural in the heat or should I be doing some scarification for the first time? If so, can anyone recommend a tool to do that?
Matt
It's a bit late now to do scarifying - should be done around April and October only. You would then need to overseed.
Keep the mowing height up to retain moisture, shallow spike the lawn and water deeply. Have a look on the lawnsmith website for useful info too.
I thought spiking is pointless where the lawn is compacted. I just end up with permanent holes.
Spiking helps de-compact the compacted lawn. It also allows water to penetrate more deeply. I'd add in some iron to help green up the lawn.
If you have been feeding and watering and its still yellow in patches it may be worth checking for leather jackets. This has been a very bad year for them where I am.
Don't fret, this is pretty unlikely and only worth looking into if you've done everything else right and its still not great.
