Scary stuff
well it DID disconnect the supply albiet not in the intended manner ;)
it was a batch of fuses that didn't meet standards apparently.
:shock: :shock:
bit severe!
The ERA said:
The ability of a fuse to clear any short circuit faults which may occur is taken for granted by users, however, recently a batch of fuses dramatically failed safety tests carried out by ERA.
These fuses, used in non-rewireable plugs on products imported into the UK, have turned out to be counterfeit. ERA performs tests on behalf of ASTA Certification Services, the Certification Body, to protect consumers from these hazards.
Fuses, used for protecting electrical apparatus against the effects of excess current, consist of a piece of fusible metal connected in the circuit to be protected, which melts and interrupts the circuit when an excess current flows. BS 1362 fuses contain sand filler to absorb the energy released when the fuse element ruptures. Standard 3 pin plugs must be fitted with a fuse link conforming to BS 1362. ASTA Certification Services provides assurance that fuses meet the applicable regulations.
To obtain certification, fuses have to meet the safety requirements for a breaking capacity current of 6kA. A fuse complying with BS 1362 would clear this short circuit current safely without any detrimental effects. In this case, the fuse could not contain the arc caused by the short circuit leading to a powerful explosion. In split seconds, the cap of the fuse blew, forcing the fuse carrier away from the base of the plug causing the plug to be ejected from the socket. It turned out the wire element and cap had been incorrectly constructed and amazingly the fuses did not contain any filler.
"It's frightening that these fuses could have found their way into people's homes. A person could have received a violent shock and severe burning and maybe even blindness caused by the explosion and flying debris. It's also likely the product would have caught fire", says Dave Treagus, Project Manager.
one thing they don't mention in the article is what happened to the rest of the batch
they sort of imply with the statement "It's frightening that these fuses could have found their way into people's homes." that they managed to actually stop this bunch of dodgy fuses but they don't actually state it anywhere.
also this was obviously a lab test. if a short has a high enough current to do that even to a badly made fuse i'd have thought it would be big enough for the rings breaker to trip out.
There are an awful lot of rewireable fuses still out there, and I'd be willing to bet there are at least a few that contain multiple bits of fuse wire, earth strands from T&E, solder, nails, cutlery, spanners, or anything else that can be forced into it to make the sockets work
and ofc cartrigge fuses can be repaired by wrapping them in foil!
Or just by soldering a bit of fusewire between the two endcaps.
30A ought to stop it blowing again...
totally scary! explosion so bad it snapped the flex clean through :shock:
Adam_151 said:
There are an awful lot of rewireable fuses still out there, and I'd be willing to bet there are at least a few that contain cutlery
Puts a whole new meaning to the phrase "on a knife edge"...
Still, when it does blow, it'll be completely forked, and then it'll spoon be all over...
The best thing I ever saw was a 4kW immersion plugged in and in place of the fuse was a portion of 6" nail....
