mapj1 said:
There are some designs of plug with removable pins, where by taking two, one can produce one plug with two neutral pins, i.e. a totally unfused plug that will look and feel like normal.
i realised you could do this from about the first plug i ever wired. cheaper to just bypass the fuseholder though that way you don't need to buy a second plug.
mapj1 said:
Almost as bad as those unfused 2 way adaptors you can still buy at ASDA for about a quid.
i belive unfused doublers are actually allowed by the BS-1363 standard
(same logic as double sockets rated at 13A total i guess)
mapj1 said:
Much more realistic is that the fault current is in the 500-1000A range, so it is likely not to be quite as bad as shown here, even if you do have aduff fuse.
and in the unlikely event you did get a 6KA short shouldn't the B32 breaker take it out pretty damn quick?!
