Quick question, I have got some ditra matting to put down before tiling my floor.
Do you have to use a rapid set adhesive? I was planning on using BAL singlepart flexible adhesive as that is what I was planning to use to tile the floor also (black galaxy style granite 300x300x9mm).
Is that ok? Worst case if needed to use rapidset then could get some Mapei from screwfix, just to fix the matting with??
Also, should I use a 4mm trowel or 3mm - they say either, but was thinking 4 might be better.
Then was planning on an 8mm round notch for the tiles.
