Hi sorry to bring this subject up yet again. I have been on here about this job before but I was just wondering if someone could clear a few things up for me please.
Basically I have a downstairs extension which had a wall in it dividing it into two halves. It has parquet floor on hardboard sheets laid on the floor.
I have removed the wall and it has left a trench which I have removed anything loose from and this trench varies from about 3cm to nearly 5cm, most of it being about 4cm. The floor is out by about 1cm either side of this trench so I was going to peal away at the parquet until I can lose the difference in a gentle unnoticeable slope if neccasery.
I was going to screed the trench to just below the lowest floor level which would make the screed closer to 3cm. Then peel back the floor until I get something acceptable and then use some of the Ardex k15 leveller to level from the top of the screed to the face level of the parquet.
Thing is the more I read the more I get confused. Some suggest 3 to 1 mixture and some 4 to 1, can someone tell me which one is best and why please?
Also as this screed is quite thin for screed what should I do with it, ie what should I put in it, PVA (how much if so), expanded metal, anything else?
How thin can a screed be and get away with it?
Also by the wall the removed wall was joined to, I can see there is a membrane under this floor. In the trench you cannot see this, just concrete so I am assuming that this is a layer of concrete over the membrane. Do I have to do anything to this concrete to make my screed stick better to it, ie PVA it?
Any advice or recommendation appreciated.
