Hi all, I hope you can throw some light on my problem..
Some history, Electrical engineer 40+ years, mostly domestic, but some 3 phase factories too. Over the years I’ve don’t a lot of drilling and mostly used black and Dekker pro electric drills. Anyway I no longer work, and it’s been about 10 years since I did any commercial work.
I’m trying to drill a concrete lintel in my house, I’ve lived here 35 years + and each room as a wooden batten fixed just above the window, where curtain rail is fixed to. In one room the batten was removed, when some new double glazing was fitted, and the wall above needed plastering.
So I’m trying to fit this wooden batten back, but have been to hell and back trying to drill it. I gave up with my black and Dekker hammer drill, and so embarked on buying a new SDS drill.
I bought a draper 1020W 5.5Kg SDS hammer drill (£70) via Amazon, it can also chisel, comes with 3 drill bits. Anyway it didn’t drill this lintel at all, it seems to be able to drill ½ inch then takes forever and a day to move in, I gave up after about ¾ inch.
Convinced the drill must be faulty, I had Amazon pick it up, and got a refund..
I rang draper, told them my thoughts, I also told them I had tested out the chisel on some concrete in the garden, and it had no effect, just a vibration. They said sounds like I was unlucky, told me to pop into Wickes and ask for a demo of one. Health and Safety, they wouldn’t test one for me, but said I could return it, if I’m not happy, so I bought the same drill with a Wickes badge on it, supplied by draper tools.
Again I tried to drill this lintel, and again it didn’t do much at all, and again I fitted the chisel and tried it out on some concrete, and other than a scratch ☺ it didn’t pound it up at all.
What’s going on, am I not using it correctly, the settings are clear, hammer and rotation..
Going back 10 years I used a hiltie SDS, but those days just drilling a 6mm hols to hold sockets, can’t say if the drill then was go or not.
Surly 2 drills can’t be faulty, Am I expecting too much ? after all this is only re-enforced concrete, and I’m not near any metal, I checked
• Hammer and rotary drilling actions
• Rotation stop for chiselling
• Supplied with 3 SDS+ drill bits and 2 SDS+ chisel bits
• SDS+ chuck
• Drilling capacities: concrete/masonry 30mm, steel 13mm, wood 40mm
• No load speed 0-800rpm
• Impact rate 3000b/min
• Weight 5.5kg
http://www.wickes.co.uk/Corded/6kg-SDS-Plus-1020W-Hammer-Drill/invt/186869
http://www.amazon.co.uk/Draper-4168...ef=sr_1_6?ie=UTF8&s=diy&qid=1235087079&sr=8-6
Specification:
Mild Steel ... 13mm
Wood ... 40mm
Masonry ... 32mm
Speed (no load) ... 800r/min
Blows per minute ... 3200 max.
Blows (energy) ... 5 joules
Weight ... 5.5kg
• SDS+ chuck
• Weight 5.5kg
Specification:
Mild Steel ... 13mm
Wood ... 40mm
Masonry ... 32mm
Weight ... 5.5kg
