I think this might be a stupid question - but can't seemed to find an answer anywhere...
I have laminate flooring in my kitchen, it is laid under the units and the units are sitting on it...
Approx 2 m across is the wall skirting joint...the expansion gap is hidden by the skirting board...
There is a wee gap under the skirting (2-3mm) I would love to seal this gap - because it will look better and also because I'm paranoid about draughts...
Skirting is white and I would love to just use white decorators caulk..(I have loads...) -water shouldn't be an issue - it is aqualoc laminate and it is well away from the sink....(should only get wet when I mop it ....which isn't that often!)
Would that be ok?
Or could I use white silicone (which I would have to go and buy...)
Or do I have to live with it -because the floor is effectively fixed at the other side?
Or buy beading (nightmare to fit behind the radiator pipes)...
Please don't say take the skirting off and do it again...the reason there is such a gap is it had warped because it had stood so long while I got round to fitting it - so it was a bit of a battle and the rest of the decorating is done now...
Would that be ok?
