- Joined
- 2 Nov 2011
- Messages
- 9
- Reaction score
- 0
- Country
I wondered if anyone had any advice on the following. I remember seeing somewhere that it was a good idea to put a bead of silicone sealant on the outside of the window around the edge of the glass and the frame, as shown in red in the picture:
The objective being, I think, to prevent water from getting into the frame. I'm not sure what is used in the construction of these windows between the glass pane and the wooden frame, but in some windows it appears to be starting to break down:
My first question is whether it is a good idea to apply the silicone sealant as mentioned and if so, should it go just along the bottom or around the whole window.
My second question is that on some windows we get a reasonable amount of condensation inside and so the same problem is possible, though to a lesser extent, i.e. condensation dripping down the window and into the frame below. Again on some windows the substance between glass and wood appears to be deteriorating:
My second question is whether it is sensible to apply the same process on the inside of the windows, e.g. clear silicone and again, if so, whether to apply just at the bottom or around the whole window.
Very grateful for any opinions on this.
