Sealed System Airlock
15 May 2006
Buckinghamshire
It appears I ahve an airlock where the upstairs and downstars returns meet. If rads are on as normal no heat in upstairs radiators. If I trun all down stairs off I get heat upstairs.
Since this has happened and just prior, very noisey in the pipes where the returns combine.
Any ideas how to fix - getting v cold.
Many thanks
In a properly designed sealed system any air should be driven to the boiler or rads where it can be bled out.
As you say nothing about your system its difficult to suggest how to deal with it.
Any heating system should obviously be correctly designed and maintained.
Sorry dont know much more about it or what to say. Was installed by a plumber last year who is now miles away.
Just know its sealed. Large hot water tank next to boiler, expansion vessel there to at 1.5bar.
T junction where the returns meet seems to be where the problem lies as the water will only return one way therefore one circuit up or down will not work when other on.
Probably just a question of Balancing (cf). Start with all the lockshield valves just a quarter of a turn open.
