Sealing an old system
8 Jan 2007
Bournemouth
Hi folks,
I'm planning to replace my venerable Crane boiler with something a bit more efficient, smaller and not in the kitchen. In fact I want to relocate a nice Broag of Valiant into the loft
I've talked it through with a relative in the trade who will do the job (technically his employer will do it as he's not individually certified but he will be doing the job through them oficially).
He has a feeling that leaving the system in its current vented setup might cause issues as there won't be a great head between boiler/pump and header tank. Sealing the system would seem to be a good solution. Plus I would prefer to go sealed
However the entire system is plumbed in stainless (Wensbury i think) with bronze(?) compression fittings used extensively in areas not easily accessible
It has never leaked but having removed a few fittings for various room refurbs the olives don't seem to have a great purchase on the pipes - there's certainly not been pipe deformation like you get on copper
I know it's an unusual system but does anyone have any thoughts ? Am I likely to open a party 7 of worms trying to pressurise this setup
Probably not that relevant but I do an annual service of a couple of weeks running system cleaner then a drain and fill with inhibitor so the joints shouldn't be held together purely with sludge deposits
Cheers
Fumb
Best solution would be to rip all the pipe out and start again. Failing that I wouldn't pressurise old stainless.
I agree - don`t pressurise it ! You`ll have to consider the boiler @ a lower level
Thanks gemts
I don't really want to start again so it looks like an alternative location is required
Are there any other inherant issues with stainless?
The whole basis of a hydraulic seal and physical retention, using olives, is keying of the olive into the parent tubing, by mechanical deformation. That's virtually impossible on stainless tube using bronze olives unless ginormous torquing of the fittings has taken place.
