sealing wood against water
15 Dec 2008
London
I'm installing a wooden bath panel. It can be cut to size. The instructions say that if you cut it you will need to seal the exposed wood.
What can I use to do that? I have a tin of B&Q Wood Primer and Undercoat, can I use that?
If not, can you recommend something that will be available in the local B&Q?
Cheers!
Do not use PVA it's water soluable :roll: you need an SBR based sealer. :wink:
Or even a couple of coats of varnish should do it; it's all I used on a home made panel we had in out last house.
