I have an 18' x 20' sectional double garage - post and panel type, just like post and panel fencing - which I'm putting a PVC coated steel pitched roof onto. At the minute, the layout with the posts and panels forms a 'U' shape like so:
o---o---o---o
o................o
o................o
o................o
At the front of this my plan is to build two 2' wide brick columns (with rebar and concrete down the middle) which will leave a gap of 14' for a double roller door.
o---o---o---o
o................o
o................o
o................o
The door is in the gable end of the building and the only thing above the door will be some OSB and PVC cladding, like so:
Can I get away with a wooden lintel to provide some bracing to the structure? The trusses will all sit on an 'L' shaped wooden wallplate which runs across the tops (4"x2") and down the sides (8"x2") of the posts. Can I just extend this over the top of the door?
o---o---o---o
o................o
o................o
o................o
o---o---o---o
o................o
o................o
o................o
