Hi
I'm fitting a new steel bath, but need some advice on how best to secure it, i.e. make it less wobbly
1. It has *one* welded-on 'lug' on each side (at opposite end from taps), as shown in the first picture here.
Assuming these are typically found on steel baths, is the one at the wall side intended to be used for securing to the wall? If so, it is not long enough to reach the wall (only bends to about 2cm from wall), so I can't see how it would work unless I fit a strip of wood to the wall first
2. The feet are shown in the 2nd picture. Unlike the acrylic bath which I'm replacing, there are no screw holes in the feet to screw them to the floor.
The result is a bath which is level and fairly snug, but clearly there is a slight wobble when I rock it. Without doing something to secure it further, I'm going to end up using a tupe of silicon every week, so what's the best way forward?
Thanks in advance
EDIT:
OK, even thought I searched before posting, I've just found this post. Do I have to build a frame, and if so, what on earth are the bits in the first picture for?
Thanks in advance
EDIT:
