Hello,
I'm currently in the research and purchasing part of fitting out my bathroom and I've got a question regarding fittings.
Got a combi boiler and decent water flow into the house.
Got a 2way thermostatic valve that's 1/2" inlets and 3/8" outlets for feed to bath filler and rain shower that required ~10ltr / min.
Was planning to run all in 15mm copper but I haven't access to a torch to solder / sweat joints so was going to do all in compression fittings.
Spoke to a plumber at work and he mentioned using full bore isolator valves on the pipework to the shower valve, are the other compression fittings (90deg. corners and Tees etc gonna make this uneccessary or will the flow rates suffer for all these constricting points?
If I'm gonna have to buy a DIY blowtorch are there any that could be recommended or conversely to avoid?
many thanks for any replies
Rob
Rob
