I'm planning a bathroom refit in the coming months and as part of that will be replacing the electric shower.
The existing shower feed is 6mm which I'm planning to swap for a 10mm as it needs re-routing anyway, however I suspect the availability of breakers for my existing consumer unit may be the limiting factor of what shower I can fit. The consumer unit is a split load GE model with Series E breakers. I don't want to add the cost of a new or additional CU at the present time so will have to work with what I've got.
I've found online that various brands of Series E MCB including Sector, Steeple and Vynckier are compatible however I can't find anything bigger than 40A which will limit me to a 9kW shower.
Are there any other compatible breakers which I would be able to source in 45A or 50A?
