Can anyone help? Got a servis easy logic washine machine, was working but stopped mid cycle and orange power light went off...tried changing the fuse but still power light wont come on? Does anyone have any ideas what the problem might be please? Thanks,
firstly i`d eliminate the problem of the socket it`s plugged into, use your hair dryer or radio or something to make sure there is power coming out of the socket, where did you get the fuse from, try a fuse from something that is working to be sure the fuse is ok, if all this points back to the machine apart from taking it apart and having a good look, you may have to call someone out, hope this helps.....
