replace it with a proper 3port valve and a timer that allows you to use hot water and central heating completely independently, it will boost performance significantly
we have an old servowarm tank wich has a lever on the front, for us to slide ovr to hot water ot heating depending on how the weather is, the lever has broken, is it poss to get a replacement. if not what would you reccomend?
