I have an old Servowarm boiler
and a mechanical lever by the HWT for switching between "heating\hot water" or just "hot water". I'm looking to have it replaced later in the year but to keep costs down I will run the necessary cables between the boiler and the tank. Question is how many cores does the flex need for a fully automated valve, plus a thermostat on the HWT.
Looking at whats there I reckon a 3port valve will fit. Its a fully pumped open vented system (if that helps)
Also, is 0.5mm flex heavy enough? I'm assuming yes as there is no load on the flex other than a small motor in the valve.
Thanks very much in advance,
Glenn
Glenn
