We have a boiler that heats water to go in the storage tank.
I have set the temperature on the tank to about 50 degrees but have no idea whether the boiler should be at maximum or some other setting.
I know maximum will heat the water the quickest but is this the right way of setting things up?
Second question - my timer has these sliders that you move round to set the time for the boiler to go on and off. The minimum time range I can set seems to be for four hours because that is the closest I can get the sliders together. Isn't this inefficient?
The tank is way too big for our needs so it seems we really are wasting hot water and gas. Is there a way of setting it up to store less water in the tank perhaps? We seem to be heating ten times as much hot water than we need!
Damian
Damian
