"Shed" for pool table in Garden
21 Jul 2010
Worcestershire
Hi all,
Im all but going to build a "shed" for a pool table in the garden. ( just got to convince myself to spend the money)
I want to use this all year round naturally.....so should it really be insulated?
Ive priced up for (from outside in)
wavey edge
baton
tyvek housewrap (any cheaper alternatives??)
4x2 stud
75mm celotex
9mm Ply
Heating will only be by a small oil heater or so when im in the room in the winter.
Or should i forget the insulation - be unusable in winter then though?
Worried about damp/condensation with the walls and ceiling stuffed with Celotex and no permanent heating.
Head and foot bearers will be sat on a single course of blue brick which will be sat on a conrete slab which wont be insulated.
Concrete slab will have a polythene sheet under it.
Input appreciated.
Many Thanks
Remember insulation keeps it cool in summer as well as warm in winter, you may actually appreciate it more in the summer, as a small space like that will be easy to heat in winter.
Condensation wont be an issue with that construction and with infrequent use, damp is only an issue if you get a leak.
Rockwool would be a cheaper alternative, polythene sheet instead of tyvek under the exterior boards.OSB is a cheaper alternative to ply.
oil heaters (assuming you mean one that burns oil, not an oil-filled electric radiator) emit vast quantities of water vapour.
