Hi guys,
I've just had a front window replaced and since the alarm sensor has gone back in (a Shockgard) it is now constantly flashing amber on the LED. Any clues as to why this might be the case?
It was basically removed and hanging by the wire while the window was fitted, but can't see any damage. It did set off the alarm when the cover was removed which is correct, and putting in my Pin it reset and pin again to clear error.
However this box is still flashing orange - all the other sensors on the rest of the house windows and doors are not. They do not flash unless you tap them.
I have tried setting the alarm and unsetting it as per some details I found on the net in another forum, but to no avail. This one still flashes.
I have tried setting off the alarm by tapping the sensor when it is set and this functions as required - the LED turns green and the alarm sounds.
On resetting the alarm - its back to flashing amber.
Any clues on how to stop this - apart from the obvious of cutting the wires..!
Thanks.
Thanks.
