Should an MVHR Exhaust vent into a cavity wall or directly outside?
20 Jun 2007
London
Hi all,
We recently discovered that our MVHR system vents into a cavity wall, with the air then escaping through an airbrick on the exterior.
We’re wondering if this setup is correct or if it could be contributing to a damp issue we’ve been struggling with.
Background:
  • We moved into our 10-year-old flat just over two years ago and have had an occasional damp spot in our bedroom, in a corner by an external wall (the wall has the airbrick)
  • Engineers have been investigating for some time, including water tests and cavity wall inspections, but the cause remains unclear.
  • The issue occurs year-round.
What we’ve recently noticed:
  • The MVHR exhaust blows directly into the cavity wall, which then vents through an airbrick.
  • There’s presently significant condensation on the cowl (which we recently added to try and reduce water ingress).
Questions:
  • Is this a normal setup for an MVHR exhaust?
  • Could this be contributing to our ongoing damp problem?
  • could condensation build up and cause this (but then this shouldnt be the case in summer would it?)
Here’s a video showing the airbrick and cavity wall.
And a photo of the airbrick (now with the recently added cowl).
Would really appreciate any insights!
You only mention the exhaust. Both exhaust and intake should be on the same wall or roof about 2 metres apart. This prevents wind blowing into one without being "balanced" by the other.
Hmm, another failure then. There is no intake on that wall at all.
