I hope someone can help me with this?
We have a damp musty smell in a bedroom which as a child I would have described as the smell of an 'old person's house'
We bought our bungalow in 2005 and I had cavity wall insulation installed. There are airbricks ar the top and bottom of the external walls of the bedroom (on the North side).
The installer sealed these but I have removed the sealant on the basis that the cavity needed some ventilation or the air bricks wouldn't be there.
There was no sign of insulation behind the airbricks.
When poking a 'stick' through the airbrick there is no opposite opening in the internal wall (no visible vents inside the house).
My floor looks like concrete but I guess it could be block and beam which could therefore have some wood construction. How can I tell?
My thoughts are that we may have blocked a vent which goes under the floor and hence causing damp which may be causing the smell in the bedroom.
Is this likely?
My idea is to ask a builder to remove an airbrick and see if I can find evidence of a problem.
Does anyone have any thoughts on this?
Eg. Will we be able to see anything that will help diagnose the problem?
Is there a more practical route?
Thank you for any advice
Is this likely?
