I have a central heating system that was seriously clogged up when I moved in 2 years ago. I had the old boiler replaced immediately and the storage tank removed, it now uses a combi boiler to heat the 5 rads. Recently one of the heaters developed a leak hole, and I have had them all replaced. Unfortunately 2 are permanently cold (one upstairs, one downstairs, both at the same end of the house).
The 2 heaters in question were just about working before, but were cold at the bottom, but after replacement are stone cold. The plumber thinks the the recent flush through could have dislodged some scale and blocked the manifold (presuming it exists). I have tried locating it, but think it may be under the bathroom tiles, which would be expensive and messy to fix, if that turns out to be the problem.
The plumber tried cold water flushing, but there is virtually no flow though the radiators, however there is still circulation when the boiler pump is on and all heaters are off, which makes it hard to force any flow through the problem radiators.
Is powerflushing likely to work? Or should I bite the bullet and start ripping floors up in an attempt to find the manifold? Note the pipes are 10mm external diameter, which I presume is 8mm microbore (please forgive my ignorance!!)
Any thoughts/suggestions?
Many thanks.
Many thanks.
