I have just moved in to a 45 year old house which is cut in to a hill side and is known to have always had a bit of water running under the floors which there is after rain. The floors are suspended wooden floors and after inspection, their joists have about 20-30% moisture content but no sign of any rot and the air bricks are all clear. The problem is the musty smells and damp air coming though to the house via gaps and old pipe holes etc. My plan is to lift the boards, treat the joists, insulate between joists, plastic membrane over joists, plywood and finally engineered flooring. I was happy with this until I read on one of the forums that I could create problems putting a DPM under the floor. Any suggestions?
