Best layed on a sand cement mix. You could use what you want at your own risk .Problem being you can leave a cavity under base and when you drop the heavy shampoo bottle {bang crack }wet floor .Once its in position anyway by the time you fit the screen and tiles with silicon seal its no going anywhere. Then again you can always hilti it to the plinth!!!!!!!
