shower cubicle bi fold door
2 Jul 2007
Cheshire
Hi all
I am changing our bi fold doors but the gap is 78cm or 780mm wide and all the products I am looking at are 760mm or 800mm, is there a way to pack the sides so the 760mm will fit? I wonder if a thick bead of silicone would do it. I`ve just read that these bi fold doors are adjustable, so if I purchased a 800mm and adjusted it down to 780mm does this sound about right or does anyone have any other ideas?
thanks
Most shower doors have around 20mm adjustment maybe more if you check the manufacturers spec's you will find one to do the job.
companies Like Matrix bathrooms even supply wider profiles to do the job but there is a lot of choice out there.
you could try www.heatandplumb.com as they have a huge range.
regards
