Shower fitting issue 15mm compression or pushfit
30 May 2013
Glasgow
I have a new shower that asked for a 15mm brass compression how ever I went to b&q and the plumber said go for the the pushfit as its quick and easy . Anyway my question is do I need to use the brass compression if so will this be ok to be used on plastic pipe?
You can use push fit plumbing for joints , except the final connection onto the shower inlet which must be 15 mm compression to ensure water tight connection.
If the manufacturers instructions ask for compression that's what you should fit, use copper olives not brass and an insert in the plastic pipe.
The connection is water tight the now with pushfit is there a reason why they was they want 15mm compression does it help water flow or something ?
Also now have a small prob where the shower is I tiled just slightly over the connection which means my freshly laid tiles 1 need to come off :;
As you've done it and it's watertight I wouldn't worry too much about it, it won't affect water flow.
One reason to do it as the manu's say is to give them no 'get outs' in case of future warranty problems.
Yeh wasn't the most expensive shower I think I could handle replacing it in a few years
the reason you have to use a compression elbow is because the shower spigot is not long enough to use a speedfit one
Speedfit do 2 types of tap connector. A brass swivel nut tap connector and a one-piece all-plastic tap connector:
The OP does not say it is electric, but he seems to suggest there is only one connection. I hadn't spotted that.
Well spotted HT5!
oh htf got in first, but he didn't take the mick as much as i would have :wink:
