    Dismiss Notice
Shower - Fused Connection (Ireland)
Discussion in 'Electrics Outside of the UK' started by Micheal_Ireland, 25 Feb 2019.
  1. Micheal_Ireland
    Micheal_Ireland
    25 Feb 2019
    3
    Thanks Received:
    Country:
    Ireland
    I'm carrying out some DIY in my apartment - during this process i'm replacing light switches, plug sockets, fused connection unit.
    The only electrical work that I am comfortable doing is like for like - replacing existing components with the full power turned off.
    The fused connection unit for the shower was wired backwards.
    Old Wiring (shower was working fine)
    FEED
    Brown -> Neutral
    Blue -> Live
    Yellow\Green -> Earth
    LOAD
    Brown -> Neutral
    Blue -> Live
    SHOWER Unit
    Blue -> Neutral
    Brown -> Live
    New Wiring (shower breaks the fuse after a few seconds)
    SUPPLY
    Blue -> Neutral
    Brown -> Live
    LOAD
    Blue -> Neutral
    Brown -> Live
    Some Questions?
    Is there any logical reason for the original fused connection to be intentionally wired wrong?.
    Why would this not have been a noticeable problem in the past?
    Why would wiring this correctly be causing me issues?
    Any advice is greatly appreciated.
  2. plugwash
    plugwash
    28 Mar 2004
    8,981
    Thanks Received:
    277
    Country:
    When you say "shower" do you mean a shower pump or do you mean an electrically heated shower?
  3. Micheal_Ireland
    Micheal_Ireland
    25 Feb 2019
    3
    Thanks Received:
    Country:
    Ireland
    It's the Fused Connection Unit for the Electric Shower
  4. winston1
    winston1
    11 Jan 2010
    4,356
    Thanks Received:
    299
    London
    Country:
    Fused connection units are rated max 13 amps. Even the smallest shower (6kW) take double this amount. Therefore fused connections units should not be used on a shower.
    I believe (correct me if I am wrong) it is illegal for you to do this work in Ireland and that the penalties are somewhat severe.
  5. Micheal_Ireland
    Micheal_Ireland
    25 Feb 2019
    3
    Thanks Received:
    Country:
    Ireland
    You are not wrong rules in ireland are very strict - nullifies your insurance and makes you ultimately responsible should any accident occur.
    I've placed back the old switch but wired it correctly - some dodgy work carried out in the late 90s construction boom here.
    A mate has a brother is an electrician and i've arranged for him to come and give things a look.
  6. Risteard
    Risteard
    18 Jun 2010
    1,635
    Thanks Received:
    107
    Derry, Ireland
    Country:
    Ireland
    All work in a bathroom (including like-for-like replacements of accessories) in the 26-Counties are Restricted Electrical Works and may only be carried out by a Registered Electrical Contractor (REC), i.e. a member of RECI/Safe Electric.
    • Thanks Thanks x 1
  7. Risteard
    Risteard
    18 Jun 2010
    1,635
    Thanks Received:
    107
    Derry, Ireland
    Country:
    Ireland
    Actually, it's punishable by imprisonment (for up to three years) and heavy fines (up to €15,000).
    • Thanks Thanks x 1
Loading...
Share This Page
