Shower Glass
21 Oct 2005
Middlesex
Hi all
I am fitting a shower upstairs and the pipework is already there as it looks like the bath used to be there.
I plan to fit a false wall at the rear and a glass screen to the left.
The problem I have is the ceiling angles down and so any screen off the shelf would be too high.
Should I purchase a 8mm screen for £50 and get it cut down or get a screen made at a glaziers.
Also not to sure what to do at the front maybe a door cut to shape?
Can you see any problems in my plans?
[/url]
I would make that a walk in wet room style shower then no need for a tray or a shower door /enclosure
I would like that and I will be tiling the whole bathroom with Limestone tiles.
Are these really OK to self fit as I heard they leak easy, Would something like This be OK.
yep that would do it but there are loads of different ones, they only get a bad name for leaking because of poor installations, I have fitted 4 different ones and never had a leak yet and I am a gas engineer not a plumber and would never profess to be a plumber, just follow the instructions and seal everything properly and you will be fine
Thanks Ian I will give it a go.
I am OK with plumbing and tiling so hopefully will be good.
I will let you know how I get on it will be a few weeks as it's the guest bathroom so won't be rushing.
:D
You need to be aware the glass used for shower screens is toughened heat treated glass. This is done after cutting and drilling etc so if you try and cut it down it will shatter into a million pieces!!!
However if you want toughened glass, and it must be for a shower screen, then it has to be made to size and with all fixing holes drilled and then heat treated to be toughened.
Hope that helps.
Just a tip Mark make sure there is no play whatsoever in the floor before you install the wet room membrane as it is movement that causes the leaks that you have heard about, use screws or ring shanks for everything dont use nails to secure the flooring as they can work loose
Good Luck and have fun doing it
Thanks for the advise guys.
Not going down the screen route now and will make sure the floor is screwed down. :)
