Shower holder replacement
25 Feb 2021
Hello,
looking for a bit of help. I’m trying to replace the shower head holder and am having difficulty removing the shower rail to do this.
I have removed the two end caps from the rail and can see there are no screws through the inside of it and I have tried to remove the gray cap on the front of the rail but it doesn’t seem to budge. I’ve attached pictures.
can anyone point me in the right direction? Any help much appreciated.
Have you checked for grub-screws below and above the end caps? Or perhaps the caps slide up and off?
I can’t get the caps to move at all, I even tried pushing them in thinking they were a button. Had no luck! I’ll have a butchers for grub screws and see! Don’t think there was any though! Thanks.
If you are replacing it then take a multi tool saw to it until you find the fixings.
Have you tried rotating the bar about its long axis to see if it will 'unscrew' from the end caps?
