shower mixer - wall vs desk mount interchangeable
11 Dec 2024
good day it is
some shower mixers are wall mount, others are desk mount (fits to bath),
anyone retrofitted DM risers to a wall mount mixer?
the spacing likely matters and ought to match, its more the fitting themselves, are they standard?
asking because theres much more wall mount options on auction sites for e.g. and I'm replacing a DM with spare risers..
thanks
Yeah standard UK bar valves are 150mm pipe centres with 3/4 inch BSP union nuts on the back, so deck mounting legs will usually screw straight on without drama. Just double check the thread depth on the legs against the valve unions so the rubber washers compress properly and don't bottom out before sealing. Saves a decent few quid buying the wall valve and legs separate tbh.
Ah, its great when standards stay put through the years...
I checked the specs of a few models listed - commonly 150mm on the mixer as you say (between center of inlets) and 180mm apart at the bath surface / riser base.
A money saver I'm sure.
