Hello,
I have a problem with my shower. To get my shower to work at a suitable temperature I have to first turn it to full hot, then gradually keep turning it colder so that it is not too hot. Then it goes completely cold and I have to turn it to full hot and then start turning it down. I normally repeat this cycle three times to have a shower.
I believe the shower is a manual mixing tap which is imbedded in the wall. The cold water comes from a tank in the roof which is shared by the six flats in the block. The hot water comes from a combi boiler. Originally the flat had an old back boiler, with a small header tank.
I thought the problem could be caused by the difference in pressures of the two water inputs.
Before I call the professionals in I wanted to do some research of my own.
Is it likely that the problems is caused by the water pressures?
What are my options to fix this. I see three and am really looking for the cheapest and most cost effective.
1) Replace the shower unit with a thermostatic mixer tap. (Least favoured as it involves removing tiles)
2) Get a pump installed.
3) Change the cold supply to be fed from the mains (most favoured)
Are there any other solutions? Is there any reason 3) cannot be done? Access to the mains supply seems possible.
Thanks in advance
C
Thanks in advance
C
