- Joined
- 24 Nov 2007
- Messages
- 16
- Reaction score
- 0
- Country
I put in a new shower. It worked fine, but the flow was a bit low, so I put a pump in. It worked first time. However....
...when I returned to the shower half an hour later it wouldn't work. Not a trickle.
So I loosened off the connections to the shower mixer, and a bit of water spat out. This flow got the pump running again, so turned off the shower, tightened up my connectors and turned on again, it worked. Turned it off, left it 5 minutes and it had packed up again just as before.
I've got narrow bore isolation valves on upstairs in the loft, which I'm going to replace them with full bore - is this constriction stopping the flow being sufficient to kick the pump in? Or do I have some other problem....
I'm not panicking yet, but its on the horizon......
