OK, so I know I'm abusing my cheapo Bristan shower pump...
I've attached split the hot water outlet pipe so it now feeds the shower AND the hot water pipes in the sinks. this was due to extremely low pressure in the hot water - no idea why and can't fix it.
So, that worked OK for a while now until reasonably recently when the pump won't shut off. It starts after you just run the hot water from a tap. You can make it stop by turning on the shower and swinging the temp from hot to cold and then off.
This feels like a switch has gone? Is this something I can fix or should I just get a new pump that can take this configuration. Is there such a pump !?
thanks,
John.
thanks,
John.
