I have recently installed a Triton Xante 2, with a rating of 8.5kw. It is wired with 45 amp shower cable, onto a separate RCD with a rating of 45 amps. It has been working fine for 6 months. Now however the RCD is making a noise and getting hot when the shower is drawing a lot of power. It will also trip out after a while. In the box, where the RCD sits onto the live bar at its base is black indicating burning. I am not too happy that the RCD is tight enough onto the bar, although you are unable to tighten it, as it clips into position from the top.
I am sure the ratings are all correct, but wondered whether the RCD might be faulty. Also, would the system have to draw more power if the water pressure is low.
