A friend of mine is going to replace his shower this coming weekend. The shower he is removing is very old and I believe it is an old 7.2kW Triton. The shower he has got his eyes on is a 10.8kW beast and I have told him that he will need to make several changes electrically. The fuse in the CU will almost cetainly need changing if not then a CU extension may need installing, the wiring between the CU and pull cord switch will need changing to 10mm as the existing is around 20 meters in length and is only 6mm, also the pull cord switch may need changing to 45A. I have also explained part P to him but he still wants to go ahead on his own and without changing anything. Could someone please advise me on what a dangerous and silly mistake he is about to make.
