Shower seat removal
29 Sep 2015
I appreciate this is the exact forum for this, but I thought maybe some of you may have experience fitting and removing shower seats.
I have one which I don't need that was there when I moved.
I began trying to remove the screws with a screwdriver. I managed to get one out but all the others wouldn't budge at all.
As well as that, there are screws that are inaccessible with a screwdriver (not enough space to access). This is what it looks like:
I cannot access the screw furthest away because the plastic is bulky and a screwdriver can't fit.
I have previously removed a similar shower seat using a screwdriver, but that one was less bulky and I could actually access the screws.
Will it need a special kind of drill to remove? Or must I somehow dismantle the seat parts before I can access the wall fittings?
Thanks in advance.
Remove the seat from the supports to give you access to the screws
If they won't move and you can't get access then you need to get physical. Angle grinder. Chop it off in bits.
