L
longdogs
I have been asked to fit a mixer shower in a downstairs bathroom, using a typical twin impeller pump. The cold water cistern is in an upstairs bedroom and offset from the downstairs hot water cylinder by about six feet resulting in pipes dissapearing into the centre of the house. This makes it impossible to run a dedicated cold feed to the pump from the water cistern, without demolishing half the house.
I contacted the pump manufacturer explaining the problem and their technical bods suggested swapping the twin impeller pump for a single impeller pump ( to pump the hot ) and to supply the cold directly from the mains ( which is in said airing cupboard ) via a pressure reducing valve, set at the same pressure as the hot pump.
The twin impeller pump was returned and swapped for a single impeller. I then rang the technical bods for the new pump who told me that I was not allowed to do this.
Can anyone see any problems with this set up? What about a non- return valve on each supply?
Any comments would be appreciated
Many thanks
Many thanks
