Hi everyone. I have converted the roofspace and added two bedrooms and an en suite. The ensuite shower is electric supplied by the cold water main. The cold tap on the wash hand basin is also mains supplied. The basin hot water is supplied from the copper cylinder downstairs. The base of the cold water storage tank in the upstairs eaves is about one foot higher than the basin hot water tap in the en suite. I can't raise the cold tank any higher, so have been thinking about fitting a single impeller pump to boost the hot water pressure to the en suite.
I'm also thinking of putting in a second bathroom upstairs, similar to the first en suite, but would be anxious to know if the hot water to the two upstairs basins could be supplied by the same pump, a twin impeller pump or two single impeller pumps?
Thanks in advance.
Thanks in advance.
