def' a bloke
def' a bloke
Wrong,female, company director,Housing Maintenance.
No, as far as I know diesel engines don`t rely on combustion.
Well there you go , u knew the answer, only a bloke would know that
a diesel engine does not have a spark plug
You have been exposed
How does a diesel engine start? explain the process from inserting the key,if you cannot,that means you are gay.Proceed.
No, as far as I know diesel engines don`t rely on combustion. Let me ask you a question. Do you know what combustion means?
You obviously don't given the first sentence
haven`t a clue about combustion.
Simples Muppets,pressure at his en suite will be lower than his pressure at his downstairs outlets because his gravity fed supplies have to climb back up to reach his taps in en suite, thus lowering pressure. I know this from experience,not doing drawings on bits of paper .
Having reread what you wrote You're obviously right in what you say, which compares to downstairs outlets. Blagards picture though compared to an upstairs outlet, but his picture didn't relate to the o.p. which you're answer does.haven`t a clue about combustion.
Same with gravity fed systems.
